will a high stall torque converter help me besides just from a stop??
Old Aug 4, 2003 | 10:16 AM
sc93's Avatar
Ok guys,
I think I decided to go with LT1Dave's stage 2 4L60 rebuild, and his 3200 stall converter.
Now I know it will hit alot harder right off the line from a stop. But will I see any gains or any differences at around 35-40 mph when I punch it?
I would assume that it would flash to the stall speed at WOT at any speed up to the lockup speed. Am I correct?
Old Aug 4, 2003 | 10:20 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
correctumundo...
it will "flash" up to the stall speed at pretty much every time... it will also not drop below the stall speed after shifting... ie: 2nd to 3rd shift won't yield rpms lower than 3200 at the begining of 3rd gear.... probably put you a little higher even
make sure you get a KILLER tranny cooler tho... high stalls = extreme heat = dead tranny converter in a VERY short time
Old Aug 4, 2003 | 10:24 AM
sc93's Avatar
thanks for the info.
I have a Hayden tranny cooler now. It was the largest one I could find, 24000 gvw I believe. You think I'm good with that?
I also have a trans temp guage to keep an eye on things.
Should I get a better converter than the LT1dave 3200? Maybe a Midwest? Torco? Edge?
I don't really want to drop the cash on a vig or yank. this is just a street car, will maybe only see the track once or twice.
Old Aug 4, 2003 | 10:27 AM
frmula1's Avatar
i got a cheap b&m... i suggest you look into a hughes with a small diameter....lt1 dave only has 12" ers... i'd look for a 10" if ya could
edit: i HAVE heard good things about midwest tho....
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
