car not running right...
Old May 12, 2004 | 12:25 PM
pyrojoex28's Avatar
when i start my car, it dies right after it starts up. takes about 5-10 seconds of cranking for it to start again.
when i get around 4000 RPM, car starts bucking and shaking. Wont rev any higher. feels like its missing really bad. when i pull up to a stop sign or light, RPMs drop to around 500 and sometimes it stalls.
but it seems to have a little more power than usual. i was just driving it and revved it up good, and when it kicked into second the tires chirped. it hasnt done that in a while.
whats going on?
Old May 12, 2004 | 12:35 PM
Heatmaker's Avatar
Advanced Member
Watch the next 15 people come and Reply about "OPTI SPARK" ... OPTI SPARK... blah blah yatta yatta yatta....
Old May 12, 2004 | 12:45 PM
pyrojoex28's Avatar
ugh, i was afraid yall were going to say that.
is there anyway to sure its the opti and not the plug wires or coil?
can i get an opti with a lifetime replacement warranty?
Old May 12, 2004 | 02:50 PM
pyrojoex28's Avatar
anybody else? im really short on money right now, and i need to be sure i get the right thing.
Old May 12, 2004 | 03:06 PM
Heatmaker's Avatar
Advanced Member
When my car had issues like starting...then not starting till 5-10 minutes later it was the Altinator I found out...that and plus a week battery....
This stalling out feeling, trouble cranking or issues like that at low rpm's can be an altinator issue.... but the 4K RPM thing is a different story. The Buckign and shaking migh be a completely different problem. You say it feels like it's missing did you check your plugs wires ETC? Do you have an MSD box? start with that suff first.
Old May 12, 2004 | 05:47 PM
pyrojoex28's Avatar
its been doin this thing with starting and stalling for a long time. but i never used to have problems with it wanting to stall at stop lights before. i just took the car out for a ride, and it revved up to 6 grand or so like it used to. its got a stumble when i kick it hard, but than it recovers and takes off. i changed the plugs without changing the wires. im wondering if i maybe screwed some of them up when i pulled them off.
would plug wires cause the SES light to come on?
Old May 12, 2004 | 07:25 PM
Heatmaker's Avatar
Advanced Member
There's a million things that can cause your SES light to come on...especially in your ignition system. At this point it might be a good idea to have the car scanned... Atleast your getting a Code for your problem.
Old May 13, 2004 | 05:32 AM
Hood_Lum's Avatar
I had the same problem with my car.
Turned out to to be a bad O2 sensor.
cmdeshon
Dec 27, 2014 10:06 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
