Will a Faulty Crank Position Sensor Affect Performance?
Old Apr 1, 2009 | 01:18 PM
  #16
METALBEAST's Avatar
Originally Posted by shoebox
Yes, but the opti is what is being used for comparison to the crank sensor. The opti calculates the crank position (which is why the LT1 does not need the crank sensor for ignition firing purposes). So, if the chain was a tooth off, the two signals being compared would never match up.
Thank you! THATS what I was trying to say.
All valves were set to 1/4 turn past 0 lash.
Old Apr 1, 2009 | 02:14 PM
  #17
ulakovic22's Avatar
Thanks for the info, but I thought the opti used a shutter wheel for the cam/crank signals, didn't think it needed to "calculate" it. Guess I need to do some research on how exactly the opti works
If the car has always run like crap since rebuilding it why wouldn't the code have popped up earlier? IIRC from my searching for my own CPS issues, long cranking times, rough idling or driving on rough roads have caused enough disruption in some cases to throw the code.
Old Apr 1, 2009 | 02:26 PM
  #18
METALBEAST's Avatar
I disconnected the battery everytime I am done. When I finally got the scanner, the car would not crank at all & I just got the TPS code.
Old Apr 1, 2009 | 05:12 PM
  #19
Perhaps "calculate" was the wrong term. The opti determines cam and crank position by virtue of the shutter wheel. The point was, it is already feeding crank position to the computer. If the chain is off a tooth, it would give the computer an incorrect position.
Old Sep 29, 2009 | 12:17 PM
  #20
n4b's Avatar
n4b
I know this is a old thread but My question is this.
I installed a 95 engine into a 96 z28 The car starts and runs but it runs rough sometimes then pops out the exhaust, How can I dissable the crank signal feed because I keep getting a crankshaft code?, Thanks
Old Sep 29, 2009 | 12:21 PM
  #21
Fix the reason it is running rough and pops (that should be your bigger concern) and the code will likely go away.
Old Sep 29, 2009 | 12:34 PM
  #22
n4b's Avatar
n4b
I should have explained myself, When cold it runs fine in open loop but in warm closed loop it starts to miss and throw codes,I also smell excess gas as it it's running too rich.
My question is can I hook the wire for the crank signal up another way since the 95 engine does not use it but the computer is picking up that it's unplugged?
Old Sep 29, 2009 | 01:32 PM
  #23
I don't know of a way you can fool it. Reprogamming could get rid of the code.
Old Sep 29, 2009 | 02:19 PM
  #24
97WS6SCharged's Avatar
The only thing you can do is to turn off the light in the PCM. It will still look for the CPS, it just won't display a code if it's not found.
The CPS won't cause the issue you're having. It's only used in the misfire detection portion of the PCM. Sounds more like an issue with the O2s such as a leaky exhaust or something. Scanning the car with Datamaster is probably your best bet.
Old Sep 29, 2009 | 03:07 PM
  #25
n4b's Avatar
n4b
That my friend is indeed the problem,I bought the car with BBK exhaust but it was a clamp together job, I will tend to that first thing tomorrow.
Thanks again for all your help
P.S shoebox,Let me know how to contribute to your site,Thanks again.
Old Sep 29, 2009 | 03:41 PM
  #26
There is a donation button on my Tech Page.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Chevyguy358
Jan 28, 2015 08:04 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
