Will a cutout cause this error code?
Old Sep 1, 2003 | 12:58 PM
Gripenfelter's Avatar
My friend has a small cutout after his headers. Its about 8-10" from the O2 sensor.
Will this cause an error code saying that side is lean? Or is it that the O2 has gone bad?
Old Sep 1, 2003 | 01:00 PM
TreySpeed's Avatar
On permanent vacation
Re: Will a cutout cause this error code?
at idle maybe, under load- nah. But then again you dont use your O2 sensors at WOT anyway so ehh, its a possibility.
Old Sep 1, 2003 | 01:03 PM
turbo_Z's Avatar
well id say no but easy way to check is to switch the sensors from side to side and see if the error follows the sensor.
Old Sep 1, 2003 | 02:43 PM
Laymaster's Avatar
Does the problem exist when the cutout is open or closed or both? If your side isn't lean when the cutout is closed, then I would say it is causing your problem.
Old Sep 1, 2003 | 03:32 PM
firebird_fury's Avatar
I just got an electric QTEC cutout for the car and after reading this post I'm wondering where exactly to put the cutout so that way I will have less of a chance of running into this type of problem. Where is the best place to put the cutout?? I should mention that I have MAC headers and their off-road y-pipe on my car. Will this problem occur regardless of position of the cutout? Thanks.
Old Sep 6, 2003 | 03:40 AM
well he capped off the cutout and it still throws the code after about 20 mins of driving.
Could he be burning an O2 sensor wire?
any other suggestions?
Old Sep 6, 2003 | 10:11 AM
Black_Z28's Avatar
Check the O2 sensors. Have you checked the code to make sure which one it is? It should tell what's going on if so.
Old Sep 6, 2003 | 10:14 AM
The injectors are new and have about 5K miles on them. Car feels like it has all the power but the ses light gives two error codes for that side.
Error 55: Lean Fuel monitor
Error 64: Right Oxygen sensor lean
Old Sep 6, 2003 | 10:29 AM
JDBlaze85's Avatar
clear the codes
un cap the cut out and drive it on the freeway, street, everywhere
if the light doesnt come back, then your cut out is the problem. A leak in the exhaust system sucks air, and if that air passes by the 02 sensor, it will go lean in a heartbeat. a loose 02 sensor sucks air too and creates lean codes. I've seen it happen.
Old Sep 6, 2003 | 02:15 PM
Car throws codes with cutout capped and uncapped.
Will a burnt O2 wire also cause these errors?
Old Sep 6, 2003 | 02:20 PM
JDBlaze85's Avatar
yeah, ALL wires must be intact
if the signal wire is melted against the exhaust, it will ground, thus pulling the 02 voltage down to 0.02 = leaner than crap
do you know what the voltage reads on that sensor?
Old Sep 6, 2003 | 02:33 PM
No I don't.
Thanx for your help.
I'll check it out when he comes by today.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
May 21, 2015 01:04 PM
91Bird305
Aug 5, 2002 01:39 PM
