Will this cam work with LT1?
Old Apr 10, 2006 | 01:50 AM
Mike96z's Avatar
Will this cam work? It's from summitracing and it's CC FI CAMS and it's the highest lift cam I've found and it says 92-97. http://store.summitracing.com/partde...5&autoview=sku
Old Apr 10, 2006 | 01:57 AM
Chopstix's Avatar
Re: Will this cam work with LT1?
yes....it is ground for the LT1 specificly
Old Apr 10, 2006 | 02:07 AM
Mike96z's Avatar
Is this the most aggresive cam?
Old Apr 10, 2006 | 02:35 AM
Chopstix's Avatar
as fas as an off the shelf grind I don't know of one any larger
Old Apr 10, 2006 | 07:54 AM
Javier97Z28's Avatar
Moderator
bigger is not always better...
what exactly are your goals for the car?
Old Apr 10, 2006 | 09:12 AM
Mike96z's Avatar
Well I'm looking for the biggest cam I can get since my cc306 had a worn lobe on the first cylinder. My car is fully modified and I am just looking to have the fastest street car in my city which the fastest at the moment is an LS1 that has 10,000$ in the engine but only pushes 500HP and has nitrous and my setup will do just about 480+ to the wheels so I wanna get the best cam I can get now.
Old Apr 10, 2006 | 09:15 AM
Moderator
You should talk to SStrokerAce (bret bauer) and see what kind of custom grind he can setup for you.
Old Apr 10, 2006 | 10:26 AM
robb4964's Avatar
If you click on the application tab it say "ltx family" and it also says 92-97 so, Yes, It will fit.
Old Apr 10, 2006 | 10:39 AM
Mike96z's Avatar
Does anyone know the biggest cam lift you can use with 1.6 ratio rockers? The CC306 is .510/.540 and this is CC468 .584/.579 lift. This cam will be better for me than the CC306 because I have ported and polished heads, tb, and intake. This car needs more fuel and air etc. because it's going to have a higher compression and bigger stroke so I have to feed it with this cam and I guess I need bigger injectors and fuel pump too.
Old Apr 11, 2006 | 01:57 PM
Chopstix's Avatar
not dure on the biggest...but I am running .613/.590
rideordie
Nov 5, 2019 04:52 PM
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
Queens94z28
Nov 20, 2014 06:03 PM
