Will a better damper help stock shortblock durability?
Old Dec 7, 2006 | 09:58 PM
JP95ZM6's Avatar
I understand that the front of the LT1 is internally balanced, and the 'harmonic balancer' is actually a torsional damper. Will upgrading that component reduce crankshaft forces or otherwise help things hold together longer or at higher RPMs?
Old Dec 7, 2006 | 10:59 PM
LenT1's Avatar
Actually a stock LT1 is externally balanced via the flexplate or flywheel as far as i know?
Old Dec 7, 2006 | 11:32 PM
JP95ZM6's Avatar
You are right about the flywheel/flexplate. I think the front is internally balanced, and the rear is externally balanced. That's why the balancer/hub has no offset weighting, but the flywheel does. Maybe it's more accurate to say the engine is externally balanced, but only at the rear?
Old Dec 8, 2006 | 12:35 AM
SStrokerAce's Avatar
If you build a 355 and use a stock crank, lighter rods and pistons and internal balance it and run a good balancer then it will be indistructable.
The balancer if it kills the harmonics in the frequencies you run in better than the stock one it will help the motor live longer.
Yes the engine is only externally balanced at the rear.
Bret
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Chevyguy358
Jan 28, 2015 08:04 PM
CARiD
Jan 27, 2015 06:27 AM
