Will a bad EGR Valve cause rough idle?
Old Mar 25, 2003 | 06:52 PM
David96Z's Avatar
Old Mar 25, 2003 | 07:07 PM
If it was stuck open, yes.
Old Mar 25, 2003 | 07:17 PM
David96Z's Avatar
I have been getting an EGR code and in the past week or so at idle RPM's have been jumping as much as 300 rpm. Is there any advantage to just removing it or should I just replace it?
Old Mar 25, 2003 | 07:23 PM
There is no real performance advantage as far as I am concerned. You could try taking it off and cleaning it or perhaps the EGR solenoid is broken and keeping the valve open all the time.
Old Mar 25, 2003 | 07:53 PM
David96Z's Avatar
Shoebox, thanks for the good info
Old Mar 25, 2003 | 08:47 PM
moparman's Avatar
There's a recall on the EGR valve. Check at a dealer.
Old Mar 27, 2003 | 03:09 PM
snorkelface's Avatar
SOmeone else also said there was a recall in this forum, but I called two dealerships, and they both insist that there is no recall.
Old Mar 27, 2003 | 04:17 PM
JSK333's Avatar
AFAIK, there is no "recall" on the EGR system, just a TSB update--which is only information for mechanics if they need to repair a car (what to look for, etc.).
Old Mar 27, 2003 | 04:22 PM
Unhappy
Dam*! I looked at it, and I just don't think I can get back there to take it off. I can barely fit my had back there, yet alone get a good look at it. I don't see how I could even get a wrench back there. My SS strut tower brace makes it even worse.
Old Mar 27, 2003 | 05:30 PM
David96Z's Avatar
I just replaced mine and it is a pain in the ***, but it is easiest laying down on the engine and coming in from the drivers side.
Oh, by the way it did not solve my problem. See other post
http://web.camaross.com/forums/showt...threadid=99508 to get info and possible help.
Old Mar 27, 2003 | 05:40 PM
Remove the STB and the EGR solenoid and you will have enough room to see and get in there.
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
jocamino
Dec 29, 2014 10:15 PM
