Will any small block double roller work?
Old Jun 3, 2005 | 01:47 AM
breakmyfootoff's Avatar
I'm switching over to a true double roller timing chain setup, I know I need to get the vented opti, timing cover, wiring harness, electric water pump, and longer dowel pin in the cam. With these changes will any standard small block chevy timing chain work or does it still take a specific part number?
Old Jun 3, 2005 | 12:50 PM
Re: Will any small block double roller work?
Does any one know, I already have a true double roller for a 95 small block that I have never used, I'm hoping it'll work.
Old Jun 3, 2005 | 03:55 PM
Dave89IROC's Avatar
as long as its for a roller cam motor, yes, you might need to grind your cover for clearance as well
Old Jun 3, 2005 | 05:45 PM
How can i tell for sure if it's for a roller cam? What is the difference between the two?
Old Jun 3, 2005 | 05:51 PM
RobBeck's Avatar
Sorry to intrude but can someone describe why all of that is needed? I have a unvented 93 and need to go double roller but am just now trying to figure out what I need to get.....
Rob
Old Jun 3, 2005 | 06:12 PM
The non vented opti is turned by a little driveshaft that fits into some plines in the cam gear, there is no true double roller timing set that has this. The later model vented optisparks are driven by the dowel pin in the cam which will work with the roller timing sets, you have to go to the electric water pump because the roller timing sets don't have the teeth to drive the water pump gear either.
Old Jun 3, 2005 | 07:56 PM
gg59c1's Avatar
I have had great luck with Comp Cams Hi Tech chain. (3136) As far as grinding out the cover I have not, but I know guys who have with the Cloyes.
Old Jun 3, 2005 | 11:36 PM
RobBeck's Avatar
Is this chain a OE replacement for the stock gears? (If so has it proven to hold up better than the stocker?)
Man that all sounded semi-doable but the electric water pump is probably pretty pricey to top it all off with.
I really am looking for the most reliable Cam Chain setup, my 10k or less stocker is REALLY stretched out....
Rob
Old Jun 10, 2005 | 07:47 AM
RobBeck's Avatar
Is this the right timing cover to go vented?
http://cgi.ebay.com/ebaymotors/ws/eB...978922524&rd=1
Old Jun 10, 2005 | 10:29 AM
Thats it.
Old Jun 10, 2005 | 10:59 AM
turbo_Z's Avatar
You must use a GM timing chain be it stock or LT4 or LT4 ED because of the drive gear used to spin the stock mechanical waterpump.
If you decide to go with an electric pump then you have several choices of TCs to use. I went with the Cloyes part# 3145 from Jegs.. its about the strongest chain out there from what Ive heard. There are others that will work as well but like someone else said they all pretty much require clearancing on the inside of the TC cover or it will rub the chain.
Old Jun 10, 2005 | 03:08 PM
RobBeck's Avatar
Thanks man.
Also I have been told the RollMaster Timing Chain Set is pretty much superior, and cost friendly. The gears look to be a good grade of steel, possibly billet. However, I also heard it can be purchased with a "normal" chain or the "much better" German or Austrian chain??? If this is true, where can I get the RollMaster with the better chain. I really like the 9 Keyways on the roll master crank gear as well
Rob
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
Queens94z28
Dec 20, 2014 09:11 PM
