will amisfire cause a check engine light on OBD1???
Old Jul 26, 2004 | 01:52 PM
  #16
944v8inDFW's Avatar
Re: will amisfire cause a check engine light on OBD1???
1993-1995 knock sensor AC-Delco #213-96 GM #10456126
Old Jul 26, 2004 | 01:55 PM
  #17
94Zpower's Avatar
Thanks!
Old Jul 26, 2004 | 01:57 PM
  #18
94Zpower's Avatar
Last question... (I hope) would the knock sensor cause the car to hesitate and seem to misfire?? or run rough?
Old Jul 26, 2004 | 02:07 PM
  #19
944v8inDFW's Avatar
I would think it could if you were getting large amounts of retard based on false reading from the sensor. Just thinking out loud.
Old Jul 26, 2004 | 02:32 PM
  #20
If the PCM sets the code for a faulty knock sensor circuit, it defaults to a pre-progammed knock retard table that will produce as much as 15 degrees of knock retard. You will "feel" it. You will see anywhere from a degree or two of retard, up to 15 degrees at all times.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
