will a 99 steering wheel work on my 93?
try it and let us know
Really I asked about my 97 gauges forever and never got a straight answer, but finally just bought em put em in and they work GREAT!!
I bet the steering wheel would work fine as well you'd be suprised how little GM changes stuff over the years, I seriously doubt the column is different from a 93 to a 99 and the SIR probably didn't change either. But with a 93 especially you probably won't find out until you try... If it does work let us know so I can go buy one
Bobby
Really I asked about my 97 gauges forever and never got a straight answer, but finally just bought em put em in and they work GREAT!!I bet the steering wheel would work fine as well you'd be suprised how little GM changes stuff over the years, I seriously doubt the column is different from a 93 to a 99 and the SIR probably didn't change either. But with a 93 especially you probably won't find out until you try... If it does work let us know so I can go buy one
Bobby
If you have the steering wheel radio contols, I would think that might be the only thing that wouldn't work. I have 97 gauges (digital mileage readout), consol (way better), and HAVC gagues (lighted *****), and they all work fine.
no i dont have the radio controls, so it should work then? but then again yours is a 94. i tried a 97 cluster out of a camaro and it didnt work so i dont know, perhaps i should call a gm dealer about this.
Bobby
Bobby
also you got your 97 cluster to work? we tried one first our of a 97 camaro and it wouldnt work in mine but it works fine in my buddies 94 and in a 95 a well.
Maybe because you tried the cluster out of a Camaro. You have a Pontiac right. All my stuff came from a Pontiac, there's not a ton of difference, but there are some. I think you will be ok. The best thing to do is pull your airbag and see how many pins are on the airbag hook ups, then check and see how many are on the new one. If they are the same, and I think they are, you should be OK.
ro2207
Dec 4, 2014 06:18 PM
turbo_Z
Aug 19, 2002 10:50 PM
formula79
Aug 6, 2002 11:18 AM
