Will a 96' lt4 shortblock work in a 95lt1?
Old May 6, 2004 | 03:19 PM
  #16
JasonL's Avatar
You won't get any power by swapping just the shortblock, as mentioned. As far as identification,
http://forums.corvetteforum.com/zerothread?id=798562
Old May 6, 2004 | 03:50 PM
  #17
ONELOUDKAR's Avatar
ok, thanks for the link
Old May 6, 2004 | 03:51 PM
  #18
ONELOUDKAR's Avatar
Hey Jason, everything will line up as far as the distributor, right? Isn't everything the same as an LT1 pretty much?
Old May 6, 2004 | 03:58 PM
  #19
Mtrhds94Z's Avatar
The other post seems to be good info..
Also the 'eyebrows' [valve reliefs] in the pistons on an LT4 are smaller..
The vented opti should go on OK along with your 95 timning cover..
Old May 6, 2004 | 04:01 PM
  #20
JasonL's Avatar
Yeah, externally the dimensions, etc. are the same. You should be able to reuse all your accessories (opti, water pump, etc)
ModdedNerd
Jan 29, 2015 07:23 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
