Will 94 shorty headers fit and hook up to a 93?
Old Jun 12, 2003 | 08:49 PM
Aeromaks's Avatar
Looking to buy some used shorty headers, and just wondering if a set off of a 94 fit my 93 lt1?
-Max
Old Jun 12, 2003 | 09:03 PM
LT1ponykilla's Avatar
Should work with no problems since both years are OBDI cars and have single cats.
Old Jun 12, 2003 | 09:05 PM
Bud M's Avatar
AIR/EGR fittings are different from 93 to 94.
Old Jun 12, 2003 | 09:08 PM
Black6SpdTA's Avatar
93 was a chip i thought
94-95 OBD1
96+ OBD2
Old Jun 12, 2003 | 09:11 PM
They are both, chip and OBDI cars.
Old Jun 12, 2003 | 09:40 PM
neil350's Avatar
Incorrect, yes they are both OBDI granted, but 93 is only the chip car. 93 is an ECM, the comp controls the engine and thats it. 94 is PCM, Comp controls engine and auto trans, thus the 4L60E. 1994 The Chip is sodered so the entire PCM has to be reprogramed.
Old Jun 12, 2003 | 09:51 PM
Thats exactly what I said. They are both. Meaning they are OBDI cars and have a chip.
Aeromaks's Avatar
my main concern is the egr and air things, must they be hooked up? or what is the deal wiht them?
93's are Chip cars, have to reprogram the chip, and yes, ODB1
Old Jun 13, 2003 | 08:06 AM
chevroletfreak's Avatar
Taken directly from my 93 specifics list (listed in my sig) -
Headers/manifolds are different. EGR gasses are only taken from right above #8 cylinder. The tube above #1 is for air injection. (94+ have an extra hole on the passenger side for a 2nd A.I.R. input.)
Old Jun 13, 2003 | 08:14 AM
KCFormula's Avatar
I have '94-'95 headers on my '93.
If you get a plate to block off the AIR it they will bolt up fine.
Old Jun 13, 2003 | 11:25 AM
always2fast4u's Avatar
I actually just went through this about 2 weeks ago. I got 94 JBA headers to go on my 93. I got a plug to fit in the AIR on the driver side headers. On the passanger side, it was plugged up. The Y pipe fits fine. I had almost no problems putting them in and since then, I have had absolutely no problems with driving other that it throwing SES at me all the time.
John
Old Jun 13, 2003 | 11:39 AM
Aeromaks's Avatar
So essentually, just need to get a blockoff plate for one of the holes? any place where to get and cost?
Old Jun 13, 2003 | 12:33 PM
I should have been more specific. Yes you can use them, but they are slightly different. All you will need is a plug for the extra hole on the passenger side or add another plug and a block-off plate to that and delete those inputs all together.
Old Jun 13, 2003 | 12:44 PM
Kris93/95Z28's Avatar
John
Check you AIR pump fuse. After doing Headers, !AIR, and !EGR They always seems to blow the fuse which causes the SES light to trip
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jason Short
Jan 19, 2015 06:34 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Killer94z
Jan 13, 2015 12:06 PM
guyomatic
Sep 11, 2002 02:11 AM
