will 94 a4 work in a 97? need answer ASAP! going to buy a tranny from someone
Old Nov 27, 2003 | 07:59 PM
MattysTA's Avatar
Just needed to know if the 4l60e from a 94 lt1 fbody will work with my 97? Thanks!!
Old Nov 27, 2003 | 08:03 PM
SantaCruz163's Avatar
Yes. I don't see why it wouldn't. You might have to change PCM settings, probably not though.
Old Nov 27, 2003 | 08:12 PM
plappo's Avatar
I wish I had more info on this, but I believe the solenoids in the valve body are different. They do the same thing, but electrically speaking I belive they have different electrical requirements. Other than that, everything else is identical. Again, I'm not 100% on that, but if there is anything, that's where to look. Might check an online tranny parts store to see if the solenoids are diff on the 94. Hope this helps you a little.
Happy Thanksgiving!
Scott
Old Nov 27, 2003 | 09:35 PM
DiabloZ's Avatar
plappo is right a 94 won't work in a 95+. Something in the controls. I wish I could remember what it was.
Old Nov 27, 2003 | 09:39 PM
The TCC solenoid comes to mind, but I am not sure if this is the only thing. Maybe you could swap the 97 solenoid to the 94 tranny when changing them.
Old Nov 29, 2003 | 02:11 AM
95patriotZ's Avatar
Or make it easy on yourself and buy my nice 95 4l60e!!!! Looking to get rid of it, great tranny at a grerat price - dajuggalo1207@new.rr.com
Old Nov 29, 2003 | 02:16 AM
madwolf's Avatar
Several of my customers run a 96-97 PCM on a 94 tranny. So that will definetely work. The wiring is probabably a little different, but it should work.
A 95+ won't work in a 94 however. (not with the stock tune and wiring)
Old Nov 29, 2003 | 06:56 AM
FASTFATBOY's Avatar
I have just the opposite, a 94 M6 car with a 97 T/A tranny. I stripped the whole harness all the way back to the computer out of the T/A, But there was one tan wire that had no place. Notindentified in the 94 GM factory manual. I didn't hook it up. Anyone know what this wire is/does? Do I need a 97 PCM? The caris not running yet, I have talked to Brian at PCM FOR LESS. He said it would work. ANy input?
David
Old Nov 30, 2003 | 12:37 PM
MattysTA's Avatar
thanks for all the info guys, but i still need a solid answer. i have to give this guy a deposit on the trans very son and i need to know if im going to have to change alot around to make this work. Thanks again........
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
heavenly_six
Dec 10, 2014 12:23 AM
Snoman73
Nov 17, 2014 07:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
