Will a 93 bbk 52mm tb fit a 94
There is only one difference between the 93 & 94 Throttle bodies - the 93 has an extra hole in the "arm" that controls the butterflies. This extra hole houses the t/v cable for the non-electronic 4L60 (a.k.a. 700R4). The 94 & up f-cars used an electronically controlled transmission and did not require such a modified "arm". All 93 t/b's will fir 94 & up f-cars (both auto & manual), but the 94 & up t/b's can't work with 93 F-cars with the automatic transmission. 94 & up t/b's can, however, be fitted on 93 F-cars with a manual transmission. Hope this clears up any questions regarding the interchangeability of the F-car's t/b...
oldschool
Feb 9, 2016 09:21 PM
ZMEFLY
Aug 8, 2001 11:40 AM
Blackie Lawless
Aug 4, 2001 02:30 PM
