Will 38 mm offset work w/ 17 in wheels
Old Mar 25, 2004 | 06:31 PM
96T56LT1's Avatar
im looking at these wheels and im curious if a 38 mm positive offset will work with a 17 inch rim. Im planning on running 275/40ZR17's. i talked to someone from discount tire and they said it might need some minor modifications like fender rolling?
thanks for the help
Old Mar 25, 2004 | 06:39 PM
jkipp84's Avatar
Here's an explanation of what the offset is.
I have 17x9.5 ZR1's with a 56mm offset and they fit just right. You can see in the diagram, by moving the hub closer to the center, the outer part of the wheel will be sticking out requiring the fender mod.
I wouldn't go with the 38mm.
Old Mar 25, 2004 | 11:20 PM
Re: Will 38 mm offset work w/ 17 in wheels
thanks for the help
No one can answer that question accurately without knowing the width of the wheel.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
ChrisFrez
Nov 30, 2014 08:41 AM
