will a 1993 camaro z28 lt1 350 engine fit in a 1997 camaro body? please help
Old Aug 12, 2007 | 11:50 PM
mtnbkrgalore's Avatar
im looking into buying a 1997 z28 body with a 1993 lt1 350 engine and was wondering if everything will fit? the engine is the reverse flow water pump that is cam driven....will it work in the 1997 body?
Old Aug 12, 2007 | 11:56 PM
reamo04's Avatar
yes, it will fit, you will have to do some things such as suspension probably, im not entirely sure, im assuming the 97 is a v6? 1993-1997 were the same bodys, z28, v6, doesnt matter
Old Aug 12, 2007 | 11:58 PM
no the 97 was a v8 6 speed but the engine is fryed. will it work?
Old Aug 13, 2007 | 12:01 AM
reamo04's Avatar
yeah, they are the same motor.....
93-97 are all LT1 v8s which are all reverse cooled, unless you have something in there that non the rest of us haev
Old Aug 13, 2007 | 12:03 AM
no its the same stuff. jus a 93 rebuilt engine. so everything should work right?
Old Aug 13, 2007 | 12:07 AM
reamo04's Avatar
correct, it will work except 1993 is speed density whereas 97 is MAF, but thats all int ehc omputer, if your using the 97 computer and the 97 intake assembly, no problem
Old Aug 13, 2007 | 12:09 AM
also do you know if you can remove the engine from the top? or do you have to drop it?
Old Aug 13, 2007 | 07:58 AM
You will have to deal with OBD-I vs. OBD-II issues. There are a few items on the 97 engine that are not on the 93 (like crank sensor, different opti, EVAP vaccum switch...). The engine can be pulled out either way.
Old Aug 13, 2007 | 09:48 AM
Injectors are a different size, knock sensors can not be interchanged. These would have to be changed to be compatible with the 97 PCM, or the injector constant changed in the PCM.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
ChrisFrez
Nov 23, 2014 10:33 AM
