Wideband O2 Tuning After the Cat Possible?
Old Jun 18, 2003 | 08:10 AM
95Blackhawk's Avatar
Going to get my car dyno'ed this weekend and they have a wideband.
I assume since the cat is designed to eliminate emissions, it is using 02 not burnt in the exhaust to do this. Well, if a wideband is being used to tune, how do you get the correct AFR after the cat? is there some compensation that must be taken into account?
Thanks,
Ben
Old Jun 20, 2003 | 01:15 AM
Highlander's Avatar
No
Old Jun 20, 2003 | 07:42 PM
Is the answer really this easy?
So no O2 is used up by the Cat trying to eliminate emissions?
That will make it easier to tune that is for sure!
Ben
Old Jun 20, 2003 | 07:46 PM
Highlander's Avatar
The cat will re burn the mixture giving you false lean condition...
That is why on OBDII cars there is a post cat o2... to make sure that the cat is working...
Weld a bung before the cat and insert the wideband there.
May 15, 2015 10:43 AM
BLK1997Z28
May 7, 2015 03:01 PM
Russ95Z28
Apr 23, 2015 01:55 PM
REDNECKISBOSS
Apr 13, 2015 07:55 AM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
