Proper Break-In for a motor
Old Jun 20, 2003 | 02:30 PM
thewinner's Avatar
What is the best and proper way to break in a brand new motor and get the rings seated etc?
Also what kind of oil should I be using and when to change it during this breakin, and when can i switch to synthetic?
Thansk a bunch!
Old Jun 20, 2003 | 06:34 PM
Fast Caddie's Avatar
At my uncle's shop, we usually start the engine and let it warm up to operating temps (about 5-10 min or until the smoking about stops). During this time we check for leaks, odd noises, and error codes in newer cars. Then we take it out on the road if everything is fine. In a 1:1 ratio gear, gently accelerate and decelerate between 1500 and 2200 rpm for a few minutes.
The idea behind this is to let the rings "cut out" the rough edges between them and the cylinder walls during the idleing period, and gently loading them on the road to get them seated over the whole ring surface (especially at the edges since rings will flex a little under load). But you keep the rpms down to keep from cutting too much. Works great.
Here's just a general way we break-in the engine:
After seating, keep the rpms under 2500 for the first 500 or so miles. Then you can get a little more aggressive and take it up to 3500 or so every now-and-then (under moderate thr.) for another 500 miles. After about 2500-3000 total miles of non-WOT, "regular" driving, the engine should be as broken in as you can get. Then romp on it at will. Use regular dyno oil for the first 4 or 5K miles then switch to synthetic if you like.
Old Jun 20, 2003 | 07:25 PM
TobyZ28's Avatar
"After seating, keep the rpms under 2500 for the first 500 or so miles"
Oops....
Old Jun 20, 2003 | 08:11 PM
96z's Avatar
96z
Ive heard of many ways to break in an engine. We went easy on mine for the first 200 miles or so and then gave it hell. No problems so far.
alex5366
Mar 27, 2015 03:30 PM
jb4xx
Feb 2, 2015 10:00 PM
Collector Car
Jan 5, 2015 10:58 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
