Why would anyone hate on the MSD Opti cap and rotor??
Old Jan 5, 2010 | 09:05 AM
  #16
dangalla's Avatar
no problems with mine either, but i also installed it with the opti out of the car
Old Jan 5, 2010 | 08:41 PM
  #17
Black 97 SS's Avatar
no problems with mine either, about 10k on it and 25 passes at the track spinnin at 6800.Hope my luck holds up.. or they fixed all the problems in it. By the way i didnt loctite the screw.
Old Jan 7, 2010 | 04:04 PM
  #18
silentsprintero's Avatar
I've had my MSD cap and rotor in since last January, about 9,XXX miles on it so far with no problems!
Old Jan 8, 2010 | 02:31 PM
  #19
z28_4life's Avatar
Originally Posted by Dwarf Killer
I was one of the first to buy the MSD opti, and one of the first to post pics of it self destructing. The problems in the first year of production were many. To start with it came with a ridiculous O-ring seal that was very difficult to install correctly on the housing without it sliding up against the housing, which would then begin riding up against the rotor and in 1000 miles your car died. Then there was the problem with the silly brass screws that didn't stay in place and couldn't be tightened enough, even with loc-tite. More than a few racers had bad days at the track because of that.
Then there's the ones that just died unexpectedly. Just stopped. No reason. It's could be because the MSD employs an immoveable shaft, unlike the stock unit that has a separate one. It would appear that the separate shaft doesn't transfer the camshaft harmonics directly to the opti the way the permanent one does. But that's just a theory. We just don't know why it fails, and at $500 a unit, we don't care. They don't last any longer than the Chinese units, so we all went back to the Delco opti, because installed correctly it is reliable.
Just so everyone knows I called and spoke with an msd tech representative about the issues with the earlier models. I called and explained my situation (wasn't able to install the product until after the warranty had expired and after 20 miles it self destructed). I also stated that there were problems with the earlier models and since then they had altered internal components to correct those issues (he did not disagree). So he was kind enough to over ride the warranty problem. I can't say that this will work for everyone with an earlier model that failed. However, in my case after 20 miles of use and having the product self destruct I feel that the least msd could do is stand behind their product. If tech shut me down I was about to call the President since they do have his extension on their web site. I will be sending my msd opti back to the factory for refurbishing.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
