Why won't my rear window defrost stay on longer than 30 secs?
Old Mar 19, 2003 | 06:53 PM
  #16
ThotYouKnew's Avatar
i went ahead and replaced the breaker with a fuse and it seems to be alright...im not sure if it is SAFE tho
  #17
Camarocks's Avatar
Originally posted by Mtrhds94Z
Safe as long as you keep the amp rating the same..
Maybe carry an extra fuse or keep the CB in case the fuse happens to pop[ mine hasn't... been about a year since I changed it]
Is the stock breaker 30 amps? I'm assuming it is, but this isn't something you want to assume with.
Old Mar 19, 2003 | 06:58 PM
  #18
Yes, if you pop the lid off and look at all the fuses/breakers.....you can see that it says 30A on the defrost/seat breaker
Old Mar 19, 2003 | 07:03 PM
  #19
96ltz's Avatar
Replaced mine with another breaker and it works fine
Old Mar 19, 2003 | 07:37 PM
  #20
It is as safe as a breaker, it is just that if the fuse blows you have to replace it. If the breaker trips, you just wait for it to reset when it cools.
Sometimes a new breaker can fix it, but most people experience that it does not.
DirtyDaveW
Dec 1, 2016 05:37 PM
guruerror
Mar 4, 2015 06:25 PM
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
