Why wont my car idle right
Old Nov 28, 2003 | 06:22 PM
acslinger2525's Avatar
I just put this motor in. Comp cam, heads and all the nice bolt ons. It wouldnt idle or shift when i first drove it. I changed the TPS and everything worked fine. Now it wont idle. It trys to idle at 300-400. the car has sat for 2 yrs before the motor was actually put in. Its got a new opti and the computer is a OBD1 conversion from madz28.com. Anyone have any idea what i can do to make this idle better. I was looking at shoebox and i was thinking about the IAC being bad. But i dont have a SES light on.
thanks for the help peoples.
Steven
Old Nov 28, 2003 | 10:29 PM
ChickenScreamer94's Avatar
you definately need a scanner-scanmaster(thunderracing.com),autoxray(ebay-got mine for 160 or jcwhitney has em for 220), or an actron scanner from jegs)
Even though you dont have an SES it may be throwing a code. Even if it is not throwing a code you will be able to see all the sensors readings.
Old Nov 28, 2003 | 10:48 PM
Scanning software w/cable and laptop or a scan tool would really be helpful. You can always check the IAC to be sure it is not gunked up as well as look over all hoses and connections.
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
Lions3
Apr 11, 2003 10:55 AM
