Why is there so nuch to do...
Old Sep 8, 2004 | 01:52 PM
'94 Bad A Z28's Avatar
... for a heads and cam install?! I'm getting a headach just looking at the motor the way it is now, hah...
Old Sep 8, 2004 | 03:45 PM
TigerWoodsJr's Avatar
Re: Why is there so nuch to do...
I hear that, I said that a few times when I looked at the bare block in my engine bay.
Old Sep 8, 2004 | 04:10 PM
WS Sick's Avatar
You should thank God we don't have overhead cams!!!!
Old Sep 8, 2004 | 05:59 PM
Z-RATED94's Avatar
The best thing to have when taking on a project like that, is a freind that's done it before. If you don't have that option just take it slow, use the search option, and refer to your manual.
Old Sep 9, 2004 | 07:43 AM
I've got that, my buddy works at a local GM Performance shop here, but with all the hurricanes and what not lately he hasn't had time to come over and finish it up with me.
Old Sep 9, 2004 | 08:21 AM
WS Sick's Avatar
Also make sure you have a metal dowel or bolt for your balancer puller because of the weird flange put inside the balancer hub.
Old Sep 9, 2004 | 08:23 AM
What kinda power did your AFR headed 383 make with the 847?
Old Sep 9, 2004 | 08:24 AM
GetaZforgetGT's Avatar
Just remember...if it were easy everyone would have a cammed LT1.
It seperates the men from the boys.
Old Sep 9, 2004 | 08:28 AM
haha... that's why I'll have a HEADS and cam.... oh and sprayed LT1 haha.
Old Sep 9, 2004 | 08:32 AM
WS Sick's Avatar
When I first put my 383 together I used the CC 224/230 XE cam, my best mph with it was a 112 mph (3750 # race weight) I later added the GM 847 havent had it properly tuned and it ran a best mph of 116.2 mph I average in the 115 range, my best ET n/a so far with the 847 cam is a 11.92 @ 115.4 mph. It has alot left in it.
Old Sep 9, 2004 | 08:36 AM
MrDude_1's Avatar
bah.
once you have all the parts and tools ready, its a days worth of work.
i actually find it kinda fun... alot more rewarding then the more boring things, like valve seal changes, fuel pump swaps, ect....
Old Sep 9, 2004 | 08:54 AM
Originally Posted by MrDude_1
bah.
Well you are more than welcome to come on down and help out. Haha, it's not that far of a drive.
Old Sep 9, 2004 | 10:09 AM
MrDude_1's Avatar
acutally ive driven to orlando before... its about a 5hour drive. not too bad.
what do you need help with?
Old Sep 9, 2004 | 11:19 AM
Well if you are seriouse, I have pretty much the whole thing to do... only really worked on it for a bout 4 hours total.
Things that are already of the car:
opti
waterpump
fans
radiator
valve covers
driver side head
intake manifold
driver side exhause manifold
o2 sensors
timing cover
timing chain and gear
oil pan is almost off (doing an oil pump aswell)
y-pipe
I think thats about it, there is still alot to do, but ohwell, it'll get done eventually.
Old Sep 9, 2004 | 03:27 PM
WS Sick's Avatar
Go ahead and mark your hood latchs position and let it hang as well, gives you that extra inch on the cam install. (that is with a buddy holding the condenser out of the way.)
Jason E
11
Oct 16, 2004 01:46 PM
1994TransAm
Oct 16, 2004 08:26 AM
camaro325
Jun 1, 2004 04:32 AM
