why are pushrod ends popping off?
Old Jul 22, 2010 | 02:14 AM
z28scotty's Avatar
I have the $40 comp hardened pushrods. I have had two of the ***** pop off the end. Could there be something wrong with with my valvetrain, or is it you get what you pay for kind of thing. The pushrods are not bent or anything. I will order a better quality pushrod. i just want to make sure there is not something else causing this.
Thanks in advance,
Scott
Old Jul 22, 2010 | 02:15 AM
RamAir95TA's Avatar
What valve springs are you running?
Old Jul 22, 2010 | 02:19 AM
z28scotty's Avatar
The combination motorsports cm 612's from about 6 years ago. they have about 20k on them.
Old Jul 22, 2010 | 02:35 AM
speed_demon24's Avatar
Could be valve float or coil bind. And for a little more get some decent pushrods.
http://www.summitracing.com/parts/SUM-1457200/
Summit owns trickflow so chances are they are trickflow pushrods.
Old Jul 22, 2010 | 07:43 AM
wrd1972's Avatar
I only run chromeoly PR's period.
Old Jul 22, 2010 | 11:50 AM
WS6T3RROR's Avatar
If you're running guide plates, make sure the slot is cut deep enough and not causing binding as the rocker sweeps through its arc. If its not binding get out 80 bucks and buy some one piece trickflow pushrods with the swaged end.
Old Jul 23, 2010 | 01:18 PM
z28scotty's Avatar
thanks for info guys. I will check the valve train out a little closer. I will order a nice set of pushrods.
Z28Freak86
Apr 30, 2024 05:37 PM
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Gtpguy
Jan 26, 2015 04:50 PM
