Why not just use Nitrious?
Old Jun 18, 2003 | 02:00 PM
WrecklessZ's Avatar
I want to run high 12s low 13s. Why should I get heads and a cam when I could just spray?
Old Jun 18, 2003 | 02:09 PM
Sweetred95ta's Avatar
Cuz, with heads and a cam, it won't hurt your bottom end. You will get a lot more life out of your engine and you will have that horsepower whenever you want. Do the heads and cam, run your high 12, then spray into the 11's!!!
Old Jun 18, 2003 | 02:15 PM
jeremyferguson's Avatar
If reliability is a factor....spraying is a little more dangerous. If you have high miles, it might not be a good idea. On a stock motor I wouldn't spray more than 125. I just bought a NX kit adjustable from 35-150, for $500. The purge kit was $100. After buying wire, connectors, steel pipe for the purge, colder plugs and other misc. crap, that's another $50. But I've got it at 100-shot now, and its a rush! I am also going to get a new fuel pump, and new plug wires. If I had the choice to make again, I'd still go with the nitrous......although later on heads and a cam couldn't hurt......
Old Jun 18, 2003 | 03:02 PM
95TA8280's Avatar
I would think a heads/cam combo with the right suspension and tuning will hit mid or sometimes low 12s (Smokin something here has a 12.3 on stock heads....)
Old Jun 18, 2003 | 03:07 PM
Antz97ZNJ's Avatar
People like different ways of making power...I rather go na and have the power on hand rather then hitting a button and risk damage to my engine...but if you know what your doing you should be fine
Chrome383Z
Jul 23, 2009 07:17 AM
LUDA0840
N2O Tech
Dec 12, 2005 03:18 PM
Mystic97Z
N2O Tech
Mar 29, 2005 09:02 AM
dsheola
Jan 19, 2005 04:12 PM
94TEALz
N2O Tech
Mar 11, 2003 11:18 PM
