why not to de-screen your maf ** read **
Old Aug 20, 2007 | 10:36 AM
  #46
jammer94's Avatar
i run fine with the screen pulled out actually no difference whatsoever i just see it as an obstruction to a car if its not driven as much as its raced.
Old Aug 20, 2007 | 05:28 PM
  #47
96capricemgr's Avatar
Originally Posted by truedualws6
Wow! I've been wondering how long this thread would go. I have the
"hated" screenless Granatelli MAF and it works just fine. I guess since
my intake tract is straight it's OK. I also yanked the screen out of the
stock MAF years ago based on the TPIS LT1 tips.
Would I do it again . . . maybe . . . maybe not. If I were dyno tuning
then yes . . . otherwise probably not.
You have a dyno tune which is correcting for the missinformation the Granatelli sends.
Tuners can overcome a lot of bad things if the car is in their hands.
Old Aug 20, 2007 | 05:34 PM
  #48
97bowtie's Avatar
What's a MAF?
Old Aug 20, 2007 | 06:12 PM
  #49
Originally Posted by 97bowtie
What's a MAF?
I don't know.... I can't find one on my engine
http://www.injuneer.com/images/photo.../DCP03746a.jpg
Old Aug 20, 2007 | 06:26 PM
  #50
FASTFATBOY's Avatar
On an LT1 non ram air car it is "straight" where the MAF is, so how is the "screen" doing anything?
David
Old Aug 20, 2007 | 06:30 PM
  #51
wrd1972's Avatar
Take your pick. I am still looking for the one that promises eleventy-thousand HP increase.
Maybe the Mechanically Attached Fitting is the way to go.
MAF Mac Addict Forum
MAF Macrophage Activating Factor
MAF Maintenance & Administrative Facility
MAF Maintenance Action Form
MAF Major Academic Field
MAF Major Accounts Facility
MAF Management Accountability Framework (Canada)
MAF Manhour Availability Factor
MAF Manpower Authorization File
MAF Marc-Andre Fleury (hockey player)
MAF Marine Amphibious Force
MAF Mass Air Flow
MAF Master Address File
MAF Master Ammunition File
MAF Mechanically Attached Fitting
MAF Media Authorization Form
MAF Medical Assisted Facility
MAF Message Acquisition and Formatting
MAF Michoud Assembly Facility (NASA)
MAF Microwave Active Filters
MAF Middle Age Friends
MAF Midland Air Field (former USAF base in Texas)
MAF Midland/Odessa, TX, USA - Midland International Airport (Airport Code)
MAF Military Airlift Forces
MAF Million Acre-Feet
MAF Mina Al Fahal (Oman port)
MAF Mineral-Ash Free
MAF Minimum Audible Field
MAF Ministry of Agriculture and Fisheries (New Zealand)
MAF Ministry of Agriculture and Food
MAF Ministry of Agriculture and Forestry (New Zealand)
MAF Minuteman Alert Facility
MAF Missile Alert Facility
MAF Mission Aviation Fellowship
MAF Mitigated Accident Frequency
MAF Mixed Amine Fuels
MAF Mobile Agent Facility (now called Mobile Agent System Interoperability Facilities)
MAF Mobility Air Forces
MAF Moisture and Ash Free (coal)
MAF Multiple-Access Forward
Old Aug 20, 2007 | 06:33 PM
  #52
David
The MAF is a hot wire anemometer. To get smooth, uniform flow into the sensor, the standard criterion for the inlet duct design would be to have a straight length of "10 diameters" in front of the sensor. 10 diameters of a 3" meter would be 30-inches, perfectly straight, and of uniform cross-section. The "straight" you refer to is not 30-inches long, and is not uniform in diameter (at least with regard to the factory part). There's a 90-degree bend in the inlet duct about 18-inches in front of the MAF, and the duct is irregularly shaped, to mold around the radiator. When you can't insure uniform distribution with the duct design, you deliberately install a restriction, to redistribute the air flow uniformly across the face area of the meter.
Old Aug 20, 2007 | 06:36 PM
  #53
TobyZ28's Avatar
David
It's far from straight, check out the plastic "tube" that goes from your airbox to the maf, its basically got a right angle cut into it so it can clear the radiator. The same goes for my K&N aftermarket cold air intake system.
Imagine a thin line of smoke being sucked into a glass intake, you'd see it swirling around right after the bend into the maf without a screen. If you do have a screen in it'll be forced to straighten out just before going past the maf sensor.
It may not be reporting numbers way off, and at certain speeds there may be varying degrees of how off it is (And at some speeds it may just be right on) but you're reducing the accuracy of the sensor readings.... and allowing for just one more variable in the equation mix to be off.
Old Aug 20, 2007 | 06:54 PM
  #54
TobyZ28's Avatar
looks like Injuneer posted a moretechnical version of what I just wrote lol...
Old Aug 20, 2007 | 07:39 PM
  #55
Sweetz28_72's Avatar
I have that same MAF and have had nothing but success with it as far as I am concerned-I have run a best of 13.27@108mph with 2.0+ 60' and its never had any problems since I installed it at 60k(now has 121K)
Old Aug 20, 2007 | 08:19 PM
  #56
rock1501's Avatar
should I expect a bottle neck in my engine(550fwhp or so) with a stock unscreened maf?
Old Aug 20, 2007 | 09:54 PM
  #57
LiENUS's Avatar
Shouldnt see a bottleneck with the stock screened maf till ~ 610 fwhp.
Old Aug 20, 2007 | 11:32 PM
  #58
OneFlyn95z28's Avatar
Good thing I learned how to program my car years ago
Old Aug 21, 2007 | 08:57 AM
  #59
baddboy1705's Avatar
great...anyone know where I can buy just a screen for my MAF?
Old Aug 21, 2007 | 12:56 PM
  #60
speed_demon24's Avatar
http://web.camaross.com/forums/showp...0&postcount=14
