Why are my Hooker LT's hitting on the drivers side of the engine compartment??
Old Nov 28, 2005 | 06:30 PM
  #16
cehan's Avatar
Re: Why are my Hooker LT's hitting on the drivers side of the engine compartment??
I had the same problem, but just as with most of the aftermarket stuff I've bought for this car, it all requires some tweeking to make it fit right. I just cut off the front part of the heat shield with a hacksaw, removed the lines from the ABS, rebent them to clear, wrapped them with fiberglass and heat shield tape and moved on. I also had to clearance and weld a reinforcement to the transmisson mount on the driver side. But, you know, if everything fit just right and just bolted on with no problems, everyone would be using this stuff.
Chris
Jan 5, 2015 07:14 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
