Why is my car still getting hot???
Old Jun 10, 2006 | 02:42 PM
Tonedef's Avatar
well i just got my motor in my car, replaced the o2 sensors, water pump is fairly new, new coolant w/ watter wetter, 160 stat, wired fans, and i can't figure out why my car is still getting hot, I guess the next thing to replace is the radiator, The car would get hot before the motor was changed, and i figured it had a slightly blown head gasket, but now i know everythign is new and don't know why its getting hot, the temp will get up to 220, 225 before i shut it down and left the fans running to cool it down.......any ideas.......before it gets really hot (cause i'm going to set it on fire)
Old Jun 10, 2006 | 03:31 PM
resa30673's Avatar
Re: Why the hell is my car still getting hot???
change the water pump thats the problem.
Old Jun 10, 2006 | 03:32 PM
Drowned's Avatar
Air in the system?
A friend's problem turned out to be his radiator cap was not sealing right... no noticeable leak, he just tried one from another car and everything worked perfectly.
Old Jun 10, 2006 | 03:51 PM
Tonedef's Avatar
Like i said i've already changed the water pump, not long before i changed the motor, so the pump is fairly new
I'll give the cap a shot, I'll try anything at this point.
Anyone else have any ideas
Old Jun 10, 2006 | 04:55 PM
fast96lt4's Avatar
Check under your radiator to see if you still have the Air Dam. I know my car when it was off would run into the 200 mark oppossed to 160 the usual. Check the lines you might have air in them ^.
Old Jun 10, 2006 | 11:50 PM
Tonedef's Avatar
yeah tomorrow I'm gonna get a new cap, bleed the system , and see if i can figure anything else out
Old Jun 11, 2006 | 12:10 AM
HardcoreRM125's Avatar
Sure its actually getting hot and the gauge isnt just off? My S10 Blazer told me every day I was overheating into the red for 2 years ...
Old Jun 11, 2006 | 12:20 AM
fredmr39's Avatar
pretty immature post IMO....
air and cap would be the first thing, most likely air...if you're down to guessing, start with the smaller things first.
Old Jun 11, 2006 | 12:35 AM
Tonedef's Avatar
HardcoreRM125 - Yeah it's not just the guage, two different aftermarket guages, same result.
fredmr39 - new cap and a system bleed is coming tomorrow
Old Jun 11, 2006 | 12:40 AM
1quikZ's Avatar
i would definetly check for air, and check the general condition of the rad make sure its not bunged up.
Old Jun 11, 2006 | 12:50 AM
revtime's Avatar
Pull the thermostat and put it in some water and heat it up to 170 to make sure its opening.
Old Jun 11, 2006 | 01:19 AM
fredmr39's Avatar
Though I know he posted that this isn't the case - that's a good point. When doing headers, I was too lazy to remove the gauge temp sensor in the block and cracked it so replaced it with w/e AZone sells - magically, my coolant was 50 degrees warmer! -proof that this wasn't the actual temp? -my fans never turned on. so ended up at the dealer for OEM part
Old Jun 11, 2006 | 02:13 AM
1racerdude's Avatar
Take the rad to a shop and have it cleaned out then do all the obvious things like cap,air,ect. This way there will be NO doubt if it's cooling or tune.
Old Jun 20, 2006 | 03:56 PM
Tonedef's Avatar
yeah so i changed the cap, bleed the system, and still getting hot, so.......next thing is taking out the radiator, and either getting it cleaned out or just getitng a different one, Hope that works
Old Jun 20, 2006 | 04:31 PM
1racerdude's Avatar
Cleaning is about $50.00,a new one is $100+. Easy choice.
