why have I seen to use a 7/16"-20 bolt for the crank hub?
Old Mar 11, 2004 | 09:59 AM
sc93's Avatar
I thought the stock bolt was 5/8"?
I'm gonna be reinstalling the hub in a day or two.
According to what i've seen, I need a 7/16-20 3" long bolt to get the hub started on, then a 2.5" bolt (7/16-20) to put it the rest of the way on?
Old Mar 11, 2004 | 03:31 PM
Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
5/8" is the head size, not the nominal size of the bolt and threads (7/16" in diameter, 20 threads per inch [7/16-20]). You really don't want to use bolts to pull the hub on. You will risk stripping out the crank threads. Better to use a high quality threaded rod with nut and washers to pull it on. That way the friction is all on the threaded rod and not on your crank threads.
Old Mar 11, 2004 | 10:09 PM
sc93's Avatar
Re: Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
That's what I figured
Now I just gotta find the threaded rod.....
Old Mar 11, 2004 | 10:10 PM
atljar's Avatar
Re: Re: Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
Napa carries it....
Old Mar 11, 2004 | 10:19 PM
sc93's Avatar
Re: Re: Re: Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
Originally posted by atljar
Napa carries it....
Thank you!
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
