why have I seen to use a 7/16"-20 bolt for the crank hub?
I thought the stock bolt was 5/8"?
I'm gonna be reinstalling the hub in a day or two.
According to what i've seen, I need a 7/16-20 3" long bolt to get the hub started on, then a 2.5" bolt (7/16-20) to put it the rest of the way on?
Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
Re: Re: why have I seen to use a 7/16"-20 bolt for the crank hub?
Originally posted by shoebox
5/8" is the head size, not the nominal size of the bolt and threads (7/16" in diameter, 20 threads per inch [7/16-20]). You really don't want to use bolts to pull the hub on. You will risk stripping out the crank threads. Better to use a high quality threaded rod with nut and washers to pull it on. That way the friction is all on the threaded rod and not on your crank threads.
That's what I figured
Now I just gotta find the threaded rod.....
stockssn2o
May 25, 2015 08:54 AM
cyteone
Feb 7, 2015 06:04 PM
