Why the first step is always: "disconnect battery"
Old May 22, 2005 | 03:01 AM
fredmr39's Avatar
Exclamation Why the first step is always: "disconnect battery"
So, heard a faint misfire - just as I had a little while ago when I wiggled spark plug number 2 and it was loose. I figured there must be another now. Armed with a 3/4 inch ratcheting box wrench and a socket I had an old HS shop teacher grind, this time I would be able to tighten whatever was lose. So, while attepting to tighten number 6 from the bottom, I slipped and hit the wrech somewhere around the starter/headers - bridging around there somewhere. The result was a nice hot shower of very bright sparks.
Now, I am curious what this may have hurt. Car started fine, MAY have taken a little longer for first start, but I tried again 10 minutes later and if was normal again.... Should I be concerned? Thanks!
Old May 22, 2005 | 03:09 AM
JBird33's Avatar
Re: Why the first step is always: "disconnect battery"
If anything I think you may have blown a fuse or something like that, I'm not really sure, but I've done similar stuff on a previous car of mine and everything seemed ok...
Old May 22, 2005 | 03:10 AM
nin97's Avatar
eh,
if it runs fine now i wouldn't be concerned...sparks are cool lookin i doubt you screwed anything up, otherwise the car wouldn't have started
Old May 22, 2005 | 06:41 AM
Rashiki's Avatar
All you did was short the positive lead from the battery that runs to the starter to a header. That should affect absolutely nothing but your hand, and maybe put a burn mark on the offending metal.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
WobblySausage
Oct 7, 2015 02:44 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
