Why doesn't my car start right away?
Old Feb 25, 2007 | 06:48 PM
KillerTA's Avatar
I have to prime it a few times (turn the key on, off, on, off, on to activate the fuel pump) or crank it a few times to start it if it's cold.
Is this a bad fuel pressure regulator?
Old Feb 25, 2007 | 07:14 PM
Spitfire557's Avatar
Get a fuel pressure gauge and test it at the schrader valve at the back of the intake manifold. Turn the key on, pressure should build, and once the pump stops priming, I'm willing to bet that the pressure drops back down to zero (while the car is off still, ignition key to "on" though). This seems to be a common thing on these cars, it's the check valve in the fuel pump, but who knows, maybe it's something more simple!
2000GTP's Avatar
It could be a bad check valve in the fuel pump. If you have access to a fuel pressure regulator, hook it up to the schrader valve on the fuel rail, turn the key to the on position, and the fuel pump should prime the system. After the pump shuts off, the pressure should hold steady. If it bleeds down rapidly, then there is a problem.
Old Feb 25, 2007 | 07:19 PM
ZL1modified's Avatar
mine bleeds down rapidly... car runs fine when it's running...(damn opti)
i think mine is due to the cheap pressure guage i bought...
Old Feb 25, 2007 | 09:13 PM
streetwarrior96's Avatar
Opti
Old Feb 26, 2007 | 02:13 AM
ColeTrains'96Z28's Avatar
Mine did the same thing. I replaced the pump with the Racetronix kit and no more problem. Good times. it's most definatley the Check Valve in the pump. ~cole~
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
