LE1 heads with Gm847
Old Feb 24, 2007 | 06:47 PM
chevyowner02's Avatar
I was thinking of going with this combo since I have the cam. Is anyone running this or would I be better off just spending the extra money and pick up the cam he dose with a set of his heads?
Old Feb 25, 2007 | 01:19 PM
69gto96z's Avatar
I'm sure you would benefit from em, but the springs he uses in the LE1 heads I don't think will handle that big of a cam.
Old Feb 25, 2007 | 02:35 PM
SStrokerAce's Avatar
True, the Crane springs can handle that lift but the GM847 is going to like a lot of RPM with ported heads so it depends on your car setup.... what gears, tranny and stall are you running around with? Where do you want your powerband to be?
Bret
Old Feb 25, 2007 | 03:38 PM
I am running 3:73 gears 4l60E and no stall. I'm try ing to stay away from a stall if I can. But from what I have read that the 847 likes the high rpm's.
Old Feb 25, 2007 | 03:43 PM
2000GTP's Avatar
With heads and that grind of cam, I would definitely consider a stall down the road.
Old Feb 25, 2007 | 03:49 PM
I was thinking of the 847 or the 306 I would like to do the whole package but dont have it in the budget.
Old Feb 25, 2007 | 04:43 PM
Man that thing is gonna suck with that much cam in it and a stock stall.
Bret
Old Feb 25, 2007 | 04:47 PM
mdacton's Avatar
man a small stall like a 3000 is hardly noticably as for drivabilty...GET ONE before that cam or you will have a problem
Old Feb 25, 2007 | 05:07 PM
speed_demon24's Avatar
Your car would be ALOT faster with a stock stall and a small cam compared to the 847/306 on a stock stall.
Old Feb 25, 2007 | 06:20 PM
The reason I dont want a stall is as of now I only have the stock rear end. And I dont know if it will hold up with out the stall. I know it wont hold up with it.What would be a good shelf cam to go with that would work good with the LE1 heads??
Old Feb 25, 2007 | 06:21 PM
Why not go with the LE1 cam?
Old Feb 25, 2007 | 06:27 PM
z95lt1's Avatar
do the le1 cam or lt4 hotcam.
Old Feb 25, 2007 | 06:32 PM
Would like to might have to but as of now not in the budget. Might have to save more. I really dont want gobbs of hp. <-- sounds stupid I know. With that hp I dont know how the rear will hold up. Dont have $ 2500 for a 12 bolt.
Old Feb 25, 2007 | 06:34 PM
Then you probably shouldn't be modding your car. Your tranny wont last long once you start modding...
Old Feb 25, 2007 | 06:41 PM
Yea I probally shouldn't but its fun.
