Why does my transmission NOT kick down when driving on the freeway? 700R4 people in!
Old Mar 3, 2003 | 03:15 PM
sc93's Avatar
Ok, I have a 93 Z28. When I am driving on the freeway, at about 60 mph and I floor it, it seems like it stays in OD instead of kicking down a gear. The RPM's don't jump up to over 5000 like they should. It goes to maybe 3000 or so and doesn't seem to pull very hard.
Again, this is a 93 with a detent cable. I tightened the cable up a little bit but I'm not sure how far to adjust it. I also have a new governor that I am going to install next week.
Old Mar 3, 2003 | 03:27 PM
DaveGrun's Avatar
My 98 WS6 does the same thing. Any ideas?
Old Mar 3, 2003 | 03:39 PM
stik6shift98's Avatar
trying going 5 mph slower and it should kick down.....
Old Mar 3, 2003 | 04:18 PM
warbird51's Avatar
Try pumping the go pedal twice real fast. That should get your tranny down a gear. Sounds weird but it works.
Old Mar 3, 2003 | 04:59 PM
stik6shift00's Avatar
get a manuel car......j/k
i heard the double pedal thing works well.
Old Mar 3, 2003 | 05:32 PM
sc93's Avatar
Thanks stik6shift and warbird!
I'll try that next time I take the car out.
Luckily this week I get to drive my mom's Envoy and I can save some miles on the Z28
I am driving something else whenever I can until the weather gets nicer, plus I just washed it and its still clean!
Old Mar 3, 2003 | 05:55 PM
PhantomTA's Avatar
Moderator
ls1 dont have 700r4's
Old Mar 3, 2003 | 06:01 PM
Gripenfelter's Avatar
Try a new TPS. (Throttle Position Sensor)
Old Mar 3, 2003 | 06:04 PM
sc93's Avatar
Thanks Grip, never thought of that
Old Mar 3, 2003 | 06:23 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
it doesn't always drop two gears dude... i have an a4 and i know exactly what your talking about... the idea is to bring the rpms into the power range. at some speeds it WILL drop to 2nd gear (thats when it goes over 5000 at highway speeds) however, depending on what speed your going when you WOT it, it will only drop 1 gear say to 3000 or so... thats how its supose to work becuase 3000 is about the MAX torque output rpm... and over 5000 is the MAX hp output
Old Mar 3, 2003 | 06:37 PM
sc93's Avatar
Interesting. So the tach not peaking when I floor it is normal at high speeds (over 65)
Old Mar 3, 2003 | 06:46 PM
sc93's Avatar
Can anyone tell me if GM part number 17106682 is the TPS I would need?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
edxiel
Jan 24, 2015 07:40 PM
CaRParts102
Dec 6, 2014 08:45 AM
Z28Wilson
Aug 1, 2002 04:27 PM
