Will Gears REALLY Help me?
Old Mar 3, 2003 | 11:02 AM
93Z286Speed's Avatar
I have a 93 Z28 6 Speed with 3.23s and a toasted Posi. now aside from the new posi unit (auburn) will the jump from 3.23s to 3.73s help me at all. This is mostly a street car, sees track time here and there. Will i feel a difference? notice a difference? Im getting the new unit so it comes with gears so i might as well get something different... no?
Old Mar 3, 2003 | 11:10 AM
You definitely will feel a difference. It will be more responsive and fun to drive (and you will have less traction). Whether it helps you at the track will be determined by whether your set-up can benefit from the higher revs available at lower speeds. If the gears were choking it back then you will lower your e.t.
If it is mostly a street car, you will probably be happy, except for the possible decrease in gas mileage.
Old Mar 3, 2003 | 11:12 AM
98ls1z28's Avatar
I never swapped gears in my previous 2 Z28s ('97 M6 and '98 M6) but when I went from the stock 3.27 to 3.73's in my '97 Cobra I noticed a HUGE difference. Probably not as much of a difference with an LT1 car as LT1's have more torque down low but all I can say is the car felt 1000# lighter! You're also running an M6 (believe 6th in your car is 0.62:1) so you won't see much of a decrease in your fuel economy and your revs probably won't go up much either. I'd vote yes! BTW, there's a gear calculator here: Clicky
Old Mar 3, 2003 | 11:24 AM
Gripenfelter's Avatar
If you can hook it will help.
Like Shoebox said, it'll be more fun to drive. You'll chirp your tires 2-3 shift because you'll be shifting at a lower speed.
If your rearend is toast you could do it. You will have to re-calibrate your speedo.
Old Mar 3, 2003 | 11:43 AM
ollie-99's Avatar
that link doesn't work
i fixxed it
http://www.f-body.org/gears/
Old Mar 3, 2003 | 11:57 AM
awsome, i really wanna do it. I plan on doing it here in the next month (car comes outta storage in 2 weeks sooo) Also how do i recalabrate the Spedo on a 93 car. Madwolf told me it cant be done on the ECU of a 93 car He said something about plastic gears and something else (its in an email somewhere) Where do i get a hold of this stuff and how much will it cost to have it done? or is it EZ nuff where i can do it myself.. i dont mind getting dirty
Old Mar 3, 2003 | 12:03 PM
97Z-M6's Avatar
i droped .3 in the 1/4 just with 3.73s then went to 4.10s and dropped .5 in the 1/4. so all in all i dropped .5 with 4.10s. and the 4.10s are aot of fun to drive also.
Old Mar 3, 2003 | 01:35 PM
Dragon Racing's Avatar
I dont mean to sound like an *** here, but are you sure that 4.10's is the only thing you did to your car and you knocked off a half second off your et? Are you sure that you just didnt learn how to drive the car better? Like i said, i dont mean to sound like an *** hole, it's just that i've never heard of anyone knocking off that much time by only swapping gears.
Old Mar 3, 2003 | 01:51 PM
i dont want 4.10s cuz i have a 93. I have the more agressive gears then the 94+'s have
Old Mar 3, 2003 | 02:00 PM
97Z-M6's Avatar
well i had the car for a year and half before i did anything to it. i ran 13.7 stock (in my opinion thats pretty good driving for stock)then i put 3.73s then 4.10s. im not saying that i jumped in the car and dropped .5 but i took quite abit of track time to get the launch down but to answer your question yes just with 4.10s and re learning to drive i dropped .5.
your not sounding like an %^&
but ive really had good luck with this car, and its always ran strong.
Old Mar 3, 2003 | 02:12 PM
sweetblue's Avatar
i have 373 and love them to death. Especially for that street racin i dont do! It is more fun to drive and launches really hard. I have a shift kit in my tranny when i had it rebuilt and it makes a world of difference. Now if i can just get it to hook.
Old Mar 3, 2003 | 03:28 PM
snake_skinner93's Avatar
you can get the plastic gears at any GM dealership... just walk in and tell them you need the plastic speedo gears for the 3.73 gear ratio set-up and they'll hook ya up. mine were like $5 each...so not bad for correcting the speedo.
Old Mar 3, 2003 | 03:31 PM
97Z-M6's Avatar
do you have the m28 or m29
I have a 93 Z28 6 Speed with 3.23s and a toasted Posi. now aside from the new posi unit (auburn) will the jump from 3.23s to 3.73s help me at all. This is mostly a street car, sees track time here and there. Will i feel a difference? notice a difference? Im getting the new unit so it comes with gears so i might as well get something different... no?[/B]
this may be somthing you want to look at first then determine the gears you want.
Old Mar 3, 2003 | 03:48 PM
all 93s with 3.23s in the rear have the same trans gears (the ones that are more agressive then the 94+'s my 1-3 gears i belive are more agressive (that gear site tells you what gears i have)
Old Mar 3, 2003 | 03:52 PM
97Z-M6's Avatar
ive never heard that all 93s come with 3.23s. not calling you a lier but what tranny do you have m28 or m29. an dwhats the rpo code.
