Why does my dipstick keep doing this?
Old Mar 10, 2004 | 03:01 PM
ONELOUDKAR's Avatar
tranny deepstick refuses to stay put
is there a locking one i can buy or can this be fixed? how and where and how much?
-Mike
Old Mar 10, 2004 | 04:18 PM
pappasmerf18's Avatar
duck tape fixes everything
Old Mar 10, 2004 | 04:31 PM
ONELOUDKAR's Avatar
there has to be another way other than that
Old Mar 17, 2004 | 06:13 PM
chesee48's Avatar
Old Mar 17, 2004 | 07:53 PM
Cmr0z28's Avatar
Seems like it's pretty common......(btw I'm MattZ28)
http://www.ws6zxr.com/showthread.php?s=&threadid=26747
Old Mar 17, 2004 | 08:04 PM
rocmemphis's Avatar
Mine has always done that too....I just ignore it
Old Mar 17, 2004 | 08:18 PM
How is your PCV system doing (mods to it?)? Any chance you might have excess crankcase pressure?
Old Mar 17, 2004 | 10:41 PM
mkent's Avatar
mine's done that ever since the day my running serpentine belt got ahold of it and bent it out of shape....i'm such a dip stick
Old Mar 18, 2004 | 07:37 AM
ONELOUDKAR's Avatar
No SHOEBOX.. no mods. What kind of mods can be done to the PCV valve? It is just everytime i lift the hood, the dang thing is
sticking out of the tube
-Mike
Old Mar 18, 2004 | 08:56 AM
LWillmann's Avatar
How would ENGINE crankcase pressure have anything to do with the tranny dipstick? I thought they were seperate systems... If it were his engine oil dipstick, I could see the crankcase pressure causing it.
FWIW: My transmission dipstick does this too. I can push it back in and drive and it will be open slightly when I open the hood next.
Could you maybe flare the end of the tube so the dipstick is a tighter fit over the end of the tube? I haven't tried that, but I wonder if it would work.
Old Mar 18, 2004 | 09:20 AM
ibanez6rg's Avatar
Time for a Lokar replacement?
Old Mar 18, 2004 | 09:57 AM
TransAm219's Avatar
Mine does it too , i know that there are some vents in the tranny that can get plugged up , I assume that is what is happening .
It dosent spit any fluid back out so i dont worry about it too much
I would rather let the tranny breath then keep pressure in there that could cause probs with the seals
is this going to cause probs for me ?
Old Mar 18, 2004 | 02:41 PM
dreamer1q's Avatar
Try checking the vent on the trans. Could be plugged up....happened to me once. Shot 2 quarts of fluid at me when I pulled the dipstick out.
Old Mar 18, 2004 | 03:20 PM
LWillmann's Avatar
Where is this vent located?
Old Mar 18, 2004 | 03:44 PM
dreamer1q's Avatar
Unfortunatly mine was at the very top of the transmission. I had to hook my arm around the trans to reach it. It is just a little piece of crap plastic vent stuck into the trans.....pretty usless, but it can get plugged.
