Why does my car sound like it has a blower???
Old Oct 30, 2004 | 03:51 PM
chevroletfreak's Avatar
I have a 93 Z that is getting upr there in miles, but is starting to show its age. Among other things the most annoying sound that it has is that of a blower sounding whine. It changes with the throttle and also with temperature. I have found that if I change my oil it tends to quite it for a short while, but I cannot keep changing oil every 1000 miles. The noise gets louder when it is warm outside, but not hot. It is also coming from the passenger side front. It sounds like it is coming from somewhere in between the altenator and the AC compressor near the front. Any ideas?
Old Oct 30, 2004 | 03:55 PM
ssbowtie1's Avatar
Re: Why does my car sound like it has a blower???
It sounds like your power steering pump. Flush the fluid and add some lucas treatment and it shoudl quiet everything down. Your other option is to buy a new one and replace it.
Old Oct 30, 2004 | 04:23 PM
Isn't that on the other side? (Drivers) I will check it out.
Old Oct 30, 2004 | 04:30 PM
30696bird's Avatar
I know on a 96 it's passenger side.
Old Oct 30, 2004 | 04:33 PM
Well, I'll be. I thought I knew a lot about my car. It sure is on the passenger side and exactly where the noise is coming from. Thanks a lot.
Old Oct 30, 2004 | 05:36 PM
jonota's Avatar
So was that your problem????
Jonota
Old Oct 30, 2004 | 06:02 PM
ponyackn's Avatar
I have the blower noise too. A board member here (what up 1BigBird3!!) pointed it out to me that it seems to be my belt and some oil that is spitting on the pulley. I have an oil leak from the timing chain cover area and it's leaving grime all over. My belt looks like it is worn too.
Old Oct 31, 2004 | 06:42 PM
WhyHelloOfficer's Avatar
My annoying whine was a bad a/c compressor. Might want to look into that as well.
-Joe
SpeedJunkee
Jan 27, 2015 10:02 PM
fpete1992
Dec 11, 2014 03:51 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Klypto
Jul 24, 2002 11:21 AM
