why does my car pull to the left while braking?
Old Jul 4, 2003 | 09:25 AM
  #16
anasazi's Avatar
Re: Re: why does my car pull to the left while braking?
Originally posted by '94 Bad A Z28
Hrm... Ever since you hit the sidewalk barrier thingy?!
no actually, this doesn't seem related to the whole curb incident
it seems as though if i apply brakes lightly it won't pull, but if i put it moderately to hard to stop at a stoplight it'll pull hard.
collapsed brake line? would this be caused by hanging the caliper from the brake line while working on it? i didn't do this, but the mechanic did
Old Jul 4, 2003 | 10:02 AM
  #17
87DJP2001's Avatar
Collasped Rubber Brakes Hoses results more from old age then any thing else. Replace with Stainless Steel Braided lines and cure your pulling problems.
Old Jul 4, 2003 | 12:14 PM
  #18
anasazi's Avatar
is this easilly diagnosed or is the only way to figure out if this is the problem replacing the hose?
Old Jul 4, 2003 | 07:47 PM
  #19
87DJP2001's Avatar
Replace the Brake hoses or take the other advice and start ripping the brake system apart. Good luck.
Old Jul 5, 2003 | 06:54 PM
  #20
raceryan's Avatar
More than likely it's the easiet culprit. The darn 20$ caliper. A new brake line is expensive, and makes no sense unless it's damaged. My 89 Camaro started pulling left under med-hevy braking, the same exact gripe, and it was the caliper. Took 20 min. to change.
Red97LT1
9
Dec 17, 2014 06:13 PM
CaRParts102
Dec 6, 2014 08:45 AM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
