why does car run different 2k rps and under after cc306?
Old Jan 23, 2005 | 12:24 PM
red96z's Avatar
i know its a big cam and a a4.whats the actual reason it runs different up until u get above 2000 rpms.and also when u hit overdrive around 40mph the rpms sit right around 2000rpm and the ride is rougher i mean feels almost like it kicks a little.i figure cause of the exhaust duration is so big but after 2000rpms feels perfect.please explain reason in mechanical terms.
Old Jan 23, 2005 | 01:04 PM
KeVMaN's Avatar
Re: why does car run different 2k rps and under after cc306?
did you get your car tuned after the cam install?
Old Jan 23, 2005 | 01:10 PM
red96z's Avatar
pcmforless tune bryan over there got me going but i figure its not the tune just the cam and being that im an a4???
Old Jan 23, 2005 | 11:27 PM
DarinsTA's Avatar
when you stepped up to that big of a cam you gave up some slow speed torque. Thats whAT the stock was good at. your yank converter should take care of your problems. also it still might be "hitting a lick" at 2000 you know how it acts at idle. hope this helps
Old Jan 24, 2005 | 12:07 AM
SSmoked's Avatar
Are the LT4 springs even big enough for the CC306? I have a CC305 with LT4 springs and im pretty sure if i went with a bigger cam the springs would of binded.
Old Jan 24, 2005 | 12:40 AM
Seal's Avatar
I had the same problem too....
i believe under 2K rpms and cruising, the cam is having 'cam surge' so it feels rough...
Old Jan 24, 2005 | 02:33 AM
BlackLT1_TX's Avatar
I really hope you are not running LT4 springs with the 306.
LT4 springs are good to like .530, CC306 exhaust lift is like .572. Hell, I run enough spring for a .730 lift cam just for added valve train dynamics.
Old Jan 24, 2005 | 07:50 AM
ejfagala's Avatar
Your problem is tune, BTW if you still have LT4 springs change them ASAP
Old Jan 28, 2005 | 10:20 PM
red96z's Avatar
no lt4 springs here i have the ls1 beehive springs and i think it is caM surge man its annoying any ideas on how to get rid of it heard when i switch to longtubes it should help or is it all in the tune.
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
