Why do you 1.6 rockers keep coming loose?
Old Jun 5, 2003 | 08:45 AM
ONELOUDKAR's Avatar
Exclamation Why do you 1.6 rockers keep coming loose?
I have been having a problem with these, they keep coming loose. Why would this be? Most of the threads on the stud show like 4-5 threads, on one of them, it's like 7 threads. What could be the problem here? I am really tired of adjusting these suckers all the time.
helpppppppppppppp
-Mike
Old Jun 5, 2003 | 09:06 AM
IDOXLR8's Avatar
You may have a bent pushrod or collapsed lifter.
Old Jun 5, 2003 | 09:34 AM
ONELOUDKAR's Avatar
If I had a bent pushrob, wouldn't I have a miss to it?
If I had a collasped lifter, wouldn't there be a ticking noise?
I am curious to this
thanks
-Mike
Old Jun 5, 2003 | 09:49 AM
Gripenfelter's Avatar
Did you tighten the center nut with a hex key?
Old Jun 5, 2003 | 09:54 AM
joeSS97's Avatar
Make sure you have them on the stud the right way.There is a recess on one side for the nut to sit.
Old Jun 5, 2003 | 10:02 AM
IDOXLR8's Avatar
thanks
-Mike
When my lifters collapsed I did not notice a ticking. What would happen was if I was cruising around the rockers would stay tight but once I gave it WOT the rocker arms would loosen up. Well I pulled off the intake manifold and it turned out to be 3 collapsed lifters.
Old Jun 5, 2003 | 11:10 AM
ONELOUDKAR's Avatar
so if it was a collapsed lifter, i wouldnt have a miss? would the car still feel strong?
Old Jun 5, 2003 | 11:50 AM
All_Z_Way's Avatar
I have heard of this more than once. So double check that your rocker is on correctly with the beveled edge up for the nut to tighten up against.
Red_94Formula
Jan 22, 2015 12:17 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
MJ_Z28
Aug 7, 2002 07:15 PM
