Why Am I Bending Exhaust Pushrods!?!?!
Re: Why Am I Bending Exhaust Pushrods!?!?!
Originally Posted by MachinistOne
I think you somehow have the cam significantly retarded
jk, Im a little more knowledgable than that. I have already checked the timing 4 times but it can never hurt to do it again.
I'm gonna rip everything back apart and check a few things that you guys have infomed me of tomorrow. thanks a ton for what you have already said and keep the suggestions coming...I want my car on the road.
That was my understanding as well. 0.541/0.576 lift for CC306 with 1.6RR. That would explain only the exhaust issue.
- Z28WannaB
- Z28WannaB
Originally Posted by Loadre
I thought 612 springs were only good to .570" lift?
the heads he is using were my heads i sold to him. when i bought them, i was told they handle .600 lift. thats the only reason i bought them...so i could run a wilder setup someday.... however my new cam speced at .602 so i switched to beehives.
- Z28WannaB
- Z28WannaB
Did you get the timing chain set that has a circle, square, and a triangle at different ends of the gears? Those are easy to get swapped up pointing the wrong shapes at each other.
yes its bending EVERY exhaust pushrod.
and what are the CM 612 springs rated at...because if it is only .570....I got ripped off, no offense blackztpi but I need to know what I have.
.570" depending upon installed height, even so they genarally allow .110" to coil bind after that number, I doubt that you are bottoming out the springs.
ok...found the problem. I installed the crank shaft timing gear sprocket on wrong.....yes Im an idiot. runs great now, lol.
new question....am I safe running my CC306(.575) with the CM612 springs?
Glad ya found the problem.
Remember that ya probably have bent valves after contacting the piston's. Do a leak test to see.
May 15, 2015 10:43 AM
