Why Am I Bending Exhaust Pushrods!?!?!
Old Jul 29, 2005 | 12:55 AM
  #16
MachinistOne's Avatar
Re: Why Am I Bending Exhaust Pushrods!?!?!
I think you somehow have the cam significantly retarded and are bending the pushrods at the end of the exhaust cycle......
Old Jul 29, 2005 | 01:05 AM
  #17
WeirdRich's Avatar
I know the car isnt running but you dont have to start calling it names....
jk, Im a little more knowledgable than that. I have already checked the timing 4 times but it can never hurt to do it again.
I'm gonna rip everything back apart and check a few things that you guys have infomed me of tomorrow. thanks a ton for what you have already said and keep the suggestions coming...I want my car on the road.
Old Jul 29, 2005 | 05:51 AM
  #18
Loadre's Avatar
I thought 612 springs were only good to .570" lift?
Old Jul 29, 2005 | 09:15 AM
  #19
Z28WannaB's Avatar
That was my understanding as well. 0.541/0.576 lift for CC306 with 1.6RR. That would explain only the exhaust issue.
- Z28WannaB
Old Jul 29, 2005 | 11:13 AM
  #20
blackztpi's Avatar
the heads he is using were my heads i sold to him. when i bought them, i was told they handle .600 lift. thats the only reason i bought them...so i could run a wilder setup someday.... however my new cam speced at .602 so i switched to beehives.
Old Jul 29, 2005 | 11:15 AM
  #21
blackztpi's Avatar
- Z28WannaB
as weirdrich noted to me before, he switched the exhaust to 1.5 rr (.540" lift) and its still bending pushrods....thats plenty under .570 anyway
Old Jul 29, 2005 | 11:39 AM
  #22
94 NO TOP Z's Avatar
Did you get the timing chain set that has a circle, square, and a triangle at different ends of the gears? Those are easy to get swapped up pointing the wrong shapes at each other.
Old Jul 29, 2005 | 12:10 PM
  #23
Loadre's Avatar
Is it bending EVERY exhaust pushrod?
Old Jul 29, 2005 | 02:11 PM
  #24
WeirdRich's Avatar
yes its bending EVERY exhaust pushrod.
and what are the CM 612 springs rated at...because if it is only .570....I got ripped off, no offense blackztpi but I need to know what I have.
Old Jul 29, 2005 | 11:55 PM
  #25
.570" depending upon installed height, even so they genarally allow .110" to coil bind after that number, I doubt that you are bottoming out the springs.
Old Jul 30, 2005 | 02:59 AM
  #26
WeirdRich's Avatar
ok...found the problem. I installed the crank shaft timing gear sprocket on wrong.....yes Im an idiot. runs great now, lol.
new question....am I safe running my CC306(.575) with the CM612 springs?
Old Jul 30, 2005 | 08:08 AM
  #27
94 NO TOP Z suggested it and I thinking the same thing reading down the page. Those marks on the double roller threw you off. The 612s are supposed to be good to .600 lift.
Old Jul 30, 2005 | 10:40 AM
  #28
Jameslt1TA's Avatar
Yes cmotorsports says they are good to 600... but i would just invest some money in 987s or some beehives for extra insurance.
Old Jul 30, 2005 | 10:45 AM
  #29
1racerdude's Avatar
Glad ya found the problem.
Old Jul 30, 2005 | 12:11 PM
  #30
1racerdude's Avatar
Remember that ya probably have bent valves after contacting the piston's. Do a leak test to see.
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
May 15, 2015 10:43 AM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
alex5366
Feb 17, 2015 08:12 PM
