Whoops! I think i just ruined my MAP SENSOR!!!
Old Jul 10, 2003 | 12:54 AM
RRios8191's Avatar
Is there a diaphragm inside of the sensor, in the tube that goes in the intake?? The one with the accordion gasket around it.
I used a paper clip to clean out some carbon and I might have punctured something. Feels like it.
Reinstalled it then...
Now car won't start!!!
Old Jul 10, 2003 | 08:00 AM
Fatdog's Avatar
Cool
I know that the gasket does have to seal tightly.Check the connector plug(wiggle the wires around),and see if this helps.
Old Jul 10, 2003 | 08:14 AM
The MAP sensor is essentially a "strain gauge".... a very thin metal diaphragm changes resistance as it deforms from the pressure (or vacuum). That resistance is used in a Wheatstone bridge circuit to provide the output signal. Why would you stick anything in it?
Also, check the harness connector. From my experience, they get extremely brittle and fall apart, giving a bad connection and an intermittent reading.
Old Jul 10, 2003 | 08:36 AM
teke184's Avatar
if you did F it up...i paid $35 for one from auto parts store last year...so they aren't that expensive...
just a FYI
sleeperZ96BT
Sep 9, 2015 08:28 AM
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
