Who says LT1's aren't strong....
Finally did some serious racing this weekend....did good and bad. Seems like I can't find third gear a lot of the time..
Well the old girl saw 7000+rpm about five times this weekend.
No noticable signs of damage and still running fine...so far. Guess GM built a pretty tough motor!!
By the way...driving lessons needed..
dude why are you going to 7000 rpm anyway..... your only making power up to 6300-6500 AT THE MOST! man you just want to blow your shi-T up! seriously dude your not going any faster buy taking it to 7000 rpm
OK...you must not have read the first post....pay attention dude. They were missed-shifts that caused the over revving. I try to shift at around 6000 but I keep missing third for some reason all of a sudden.
Thanks...I'll try shifting at a little lower RPM. I have heard of the 5.0 shifter. I made a post in the drivetrain forum but no one has responded. All of a sudden when I go to shift into 3rd it hangs up in neutral. It has a Hurst short throw shifter on it now....don't know if there is any adjustment that can be made or not. Is the 5.0 that much better....or do iI just need a new driver?
Why is it set for 7,000 ???? Look at my sig, I have mine set to 6,000 and even that is probably to high... I've hit 6k many many times with no problems to date, but still its a high risk to take. 7k
Originally posted by Hyperspeed97z28
M6 with a 3:23 rear ????
The 93 F-Body did not get a 3.42 rear. If you had the M29 coded M6, you got a 3.23 rear. The M28 tranny got the 2.73 rear.
Whatsup, On another note, have you checked out the speed density F-Body forum?? Speed Density LT1 Forum Good people, good info, not as packed, 93 F-Car specific. You may like it.
so were they M6 dogs ? SLOWER?
