Who makes 65cc or larger lt1 head
Old Jan 21, 2010 | 04:46 PM
stephenpen's Avatar
I'm looking for a set of heads that have a larger then 65cc combustion chamber.
Who makes them. 75cc would be perfect.
thanks in advance
Old Jan 21, 2010 | 04:59 PM
RamAir95TA's Avatar
Why do you need such a big CC?
Old Jan 21, 2010 | 05:05 PM
stephenpen's Avatar
larger then 65cc lt1 heads
I need to lower my compression ratio from 11.0 to 9.5 or lower. I'd rather replace my stock ported heads then do the bottom end again.
Old Jan 21, 2010 | 05:14 PM
RamAir95TA's Avatar
Static compression is only a build figure and has no impact on overall engine performance. Depending on what type of cam you plan on running you may not need such a big CC'd head to get the desired dynamic compression ratio.
Can you provide a little more info on your build? I'm assuming you're going to be going FI?
Old Jan 21, 2010 | 05:16 PM
n2ceptor's Avatar
Trick Flow carries a 62cc..... Thats the biggest I know of; off the shelf...
Old Jan 21, 2010 | 05:20 PM
stephenpen's Avatar
AFR makes a 65cc
Old Jan 22, 2010 | 08:23 AM
RealQuick's Avatar
AFR makes a 64cc and 76cc I believe.
Old Jan 22, 2010 | 08:59 AM
rskrause's Avatar
Moderator
AFR 76cc chamber LT1 and LT4 heads.
Rich
Old Jan 22, 2010 | 05:46 PM
stephenpen's Avatar
I spoke with them about that. They have not made a LT1 head larger then 65cc since 2005. It says 65-75cc on there site but that is not correct.
Old Jan 22, 2010 | 06:56 PM
rskrause's Avatar
Moderator
Mine are old!
Rich
Old Jan 22, 2010 | 07:18 PM
stephenpen's Avatar
What heads do you have.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
birdblack
Dec 30, 2014 06:59 PM
