Who here has done a auto to M6 swap?
For those guys that did this swap, do you have issues where the tranny seems to vibrate a bit when at idle? My torque arm is tight and so it the tranny mount, but still seems to vibrate a bit when it is idling. I have a Fedenza flywheel which has been balanced, and torqued to spec, also a McLoud clutch...any suggestions?
Re: Who here has done a auto to M6 swap?
I did the swap and I do have a vibration problem but then again i do have a Cam in my car so its kind of hard to tell sometimes. But I know I have vibrations while cuising.
I have a poly mount for the tranny, the original didnt hold as tight as the poly one does. When I am at idle, seems like the input shaft from the tranny that going into the pilot bearing is rubbing or something.....
carguyshu
Jan 22, 2017 11:19 AM
Nostang 96z
Sep 14, 2002 08:22 PM
