Who has put 450+ rwhp NA using a LT4 intake?
Old 01-17-2005, 08:51 PM
Black95Form's Avatar
I am building a serious 383 solid roller direct port n2o motor. I was wondering if anyone has got close to 500 rwhp NA using a LT4 intake? If so, what was done to the intake?
Black95Form is offline
Old 01-18-2005, 06:24 AM
texasTA's Avatar
Re: Who has put 450+ rwhp NA using a LT4 intake?
Hey Michael, this is Matt (going to buy your cage). I am doing the same setup as you. I already have a set of fully ported LT4 heads by Jordon and a ported LT4 manifold. It is going on top of a fully forged 383 motor with a solid roller setup. The cam is a Cam Motion cam at something like .650 lift on the intake side I am running a a4 behind this and everyone, including Jordon, believe that this setup is going to see between 460rwhp to 480rwhp. So yeah, I believe it is doable. I am also going to be spraying a 300 shot on top of it.
texasTA is offline
Old 01-18-2005, 09:41 AM
RiceETR96's Avatar
I made 457 on a ported LT1 so 500 should be no problem with a LT4 thats been ported.........
RiceETR96 is offline
Old 01-18-2005, 09:56 AM
'94 Bad A Z28's Avatar
I am sure you can do it, I am hoping to make in that area with just a 'lil 355.
'94 Bad A Z28 is offline
Old 01-18-2005, 10:02 AM
95Bird's Avatar
I put down 458 rwhp with lt4 heads/intake and it was having some major issues when it did that. It should be in the mid/high 465 range when all is sorted out. This is a 355 with 4.71s and a 9" so your goal should be pretty easy with the extra cubes.
95Bird is offline
Old 01-18-2005, 10:10 AM
95Bird,
What did you do to your intake? Any welding? Please let me know.
Michael
Old 01-18-2005, 10:45 AM
95Bird's Avatar
intake is welded to raise the runners and fully ported. Its also opened up for a monoblade. The intake work made a big difference on the flow bench. Steve stumph(SAR2K) did all my work.
95Bird is offline
LT14LIFE
02-09-2015 09:35 PM
MadMav
02-06-2015 11:02 PM
ModdedNerd
01-29-2015 07:23 PM
95chwagon
01-13-2015 09:19 PM
Quick Reply: Who has put 450+ rwhp NA using a LT4 intake?
