Who has put 450+ rwhp NA using a LT4 intake?
I am building a serious 383 solid roller direct port n2o motor. I was wondering if anyone has got close to 500 rwhp NA using a LT4 intake? If so, what was done to the intake?
Re: Who has put 450+ rwhp NA using a LT4 intake?
Hey Michael, this is Matt (going to buy your cage). I am doing the same setup as you. I already have a set of fully ported LT4 heads by Jordon and a ported LT4 manifold. It is going on top of a fully forged 383 motor with a solid roller setup. The cam is a Cam Motion cam at something like .650 lift on the intake side I am running a a4 behind this and everyone, including Jordon, believe that this setup is going to see between 460rwhp to 480rwhp. So yeah, I believe it is doable. I am also going to be spraying a 300 shot on top of it.
I put down 458 rwhp with lt4 heads/intake and it was having some major issues when it did that. It should be in the mid/high 465 range when all is sorted out. This is a 355 with 4.71s and a 9" so your goal should be pretty easy with the extra cubes.
intake is welded to raise the runners and fully ported. Its also opened up for a monoblade. The intake work made a big difference on the flow bench. Steve stumph(SAR2K) did all my work.
95chwagon
01-13-2015 09:19 PM
