Who has an oil leak ? ?
Well first off I use 10W-30 Castrol Synthetic oil, so I know thats not helping the leak situation. I think it might be coming from the oil pan. It only drips a few drops a day, nothing major, (or at least compared to my VW bug, hahahaha) Id say that I would lose 1 quart every 3 months. when i went to change my oil i was a quart low. I watch the **** now so its cool. I was wondering, does anyone else on here drip oil at the same rate or at all ? ? ? can it be fixed ? ... it minor so im not gonna bother I think ....
dang a quart a week. I would get on that right away. yeah mine is dripping down by the starter, so it might be from the intake.... hmmm I wonder if i should buy that lt4 intake and knock out two projects with one stone !!
back of my pan is also leaking.....cant seem to get a nice layer of rtv on it with that auto tranny and flywheel in the way, one of these days ill redo it (again)....i leak about 4-5 drops overnight
I think I have the same problem rocmemphis mentioned but its not a quart, doesnt drip and is caked on pretty good. That must be why it doesnt leak! I'm not going to clean it off you can bet on that!!
Are you sure it's not the intake manifold leaking and running down the back of the engine to the oil pan?
You can reach behind the top of the engine and feel back there. If it comes back with oil, most likely you have an intake manifold leak. Just a thought.
Dan
Dan
my "oil" leak is from the rear diff seal. I need that replaced and get a t/a girdle.
can't find a good deal anywhere for one.
I found my crank seal was gone, so I bought a cam to go with my crank seal install.
"dang a quart a week. I would get on that right away. yeah mine is dripping down by the starter, so it might be from the intake.... hmmm I wonder if i should buy that lt4 intake and knock out two projects with one stone !!"
The LT4 intake is only for LT4 heads i belave
Originally posted by rocmemphis
I have an oil leak which I believe is coming from the WP driveshaft seal. I loose a quart every single week. Maybe I should fix it
I swear these dang things seem to leak right through the block! no need for the oil to go out the seals. my 95 hasnt had a problem yet, but Im in the middle of heads/cam swap, so let the leakin begin. lol
and I believe that the LT4 intake has raised ports, thats why your not "supposed" to use it. since the ports will not line up w/your heads. so w/o the heads, your defeating the purpose of replacing the intake. as in your prolly goin to lose power. unless your purpose is to have a nice shiny red intake.
chris
chris
