Who has hammered their hub on and been fine afterwards???
Old Nov 11, 2003 | 05:35 AM
96 WS6's Avatar
I need some reassurance. Is there any way to check for damage before I crank the engine? Hammering that stupid thing on was my only hope so I went ahead and did it. I want to know what my chances are that I messed something up? I really hope that I did not, I'd like to check ASAP though to make sure. I can't have this happen right now especially after buying and installing all this top end stuff I just did. Screw the hub to hell.
Old Nov 11, 2003 | 06:22 AM
joeSS97's Avatar
I did.Didnt really hammer it hard,just enough to start the bolt and draw it on.It went on pretty easy.
Old Nov 11, 2003 | 06:35 AM
96 WS6's Avatar
You got lucky... I stripped the first bit of thread, then the last bit of thread. Then I helicoiled the hole and I did not want to risk messing up the helicoil or that hole and that crank would have been shot to hell. I just hope and pray that I did not mess up the thrust bearing. I tried not to hit it too hard, just repeated tapping hits to make it go on but I hammered it the whole way on. I think it may have been so hard because it was a brand new hub. Either way, I need to know the odds of messing something up to know what to expect. Will the engine immediately make bad sounds if I messed up the bearing... Is it possible to disalign the crank??? Although I don't know how exactly that could happen but anything is possible. Please let me know asap.
Thanks.
Old Nov 11, 2003 | 08:48 AM
BradZ28's Avatar
I used a rubber mallet. I was more concerned with damaging the threads than messing up a main bearing, that's why I hammered it on most of the way. It's fine but I only have 500 miles on it since the top end was put on. I wouldn't use a steel hammer, the shock to the crank is much less with a rubber mallet.
Brad
Old Nov 11, 2003 | 09:24 AM
bradpreece95z28's Avatar
I used a brass hammer to "tap" it on.
I tried to get it on with the bolt, and managed to mangle a couple of threads on the crank.
if you didnt BEAT THE HELL out of it, I would think you wil be ok my friend.
BTW....seems like you and this hub are pretty well acquainted, bet you look forward to messing with it som more
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
