who has actually cc'd a set of factory LT1 heads?
Old Aug 20, 2005 | 12:07 PM
dhirocz's Avatar
I've searched and it's come up with nothing solid...anything from 52 to 58. I'm trying to swap pistons so I can get my compression up in my stroker motor and it depends on the size of the head as to which piston I go with because I think 13:1 it a little too high So who has actually cc'd a set of stock LT1 heads? Mine are LE3's so the valves are slightly bigger (2.00/1.56) but they should be about the same.
Anyone?
Old Aug 20, 2005 | 12:37 PM
1racerdude's Avatar
Re: who has actually cc'd a set of factory LT1 heads?
54 on the ones that haven't had the combustion chamber worked. I haven't done any '93's.Call Loyd and see what your heads are.
13/1 isn't high,it depends on the DCR which is dependent on your cam.
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
cmdeshon
Jan 4, 2015 11:15 AM
hotrodyou1
Dec 20, 2014 10:05 PM
